[quote=“Fanan, post:11, topic:190323”]Thanks for the information. I’m a real newbie to this and are having a hard time trying to understand all of it. I have a Samsung Galaxy S5, so it’s a android. It’s there any guides available for us newbies? Especially when it comes to using vera proximity. I looked at their website, but couldn’t find any useful information. Thanks once again for your help!
Skickat fr?n min SM-G900F via Tapatalk[/quote]
Unfortunately I don’t know of any guides for the VERA proximity App.
This app and a few other plugins and apps were all developed by a very active user here on the Forums. Richard has his own website which has limited information on it and there there is the specific spots ( or not so specific in the General box) on the forum to discus the apps/plugins. But those many help with answering direct questions not A-Z installation.
http://rts-services.com/Android/VeraProximity/ (looks like it’s no longer up)
I would say that even for a newbie the steps are not totally difficult and many people will offer assistance if asked.
You need to install the app, add your vera credentials, go to settings and setup a registration key (cost I think 5.95 per device one time you want to use it on, you can add more later)
Use the circle with a dot to make a new location (home should be your first one, but I also have more including work) and after the location is set then you can add a fence. Fence size can be adjust and you can use multiple fences around you house. Don’t want to over complicate it for you starting off but you can have a small fence and a larger fence for backup. You can also have the larger fence put your phone in rapid update when getting home so your smaller fence will trip faster. Don’t get worked up into those things until you get the basics down.
When you click on fence settings you can choose what happens when you enter or exit a fence.
Local alerts = means beep or vibrate your phone.
SMS = text u
Vera Action = the main one you should check and use which would be have vera do something!
Mobile Device Unlock Required = If your device is locked and needs to be unlocked (I don’t use this)
with VERA Action checked you need to select your vera serial below (mush have your vera credentials already setup)
Choose which action (run a scene, flip a virtual switch or what ever) I use virtual switches myself but that’s another lesson.
Rapid update on the bottom is used to put your phone in rapid GPS checking mode and have it check your position over and over again fast to watch for a fence crossing coming up. This drains battery, so location updates (by phone default) are generally every few min to keep from draining your battery. If you set a large fence around your house say .5 to 1 mile with like 3 to 5min. and set rapid update when entering that large fence (no vera action yet) then set a small fence around your house the small fence will trip fast (run a vera action, to say your home) since your phone was put into rapid update mode before hand.
