Hi
I wanted to try and add my home broadband router by using Vera’s own add a PnP device option under UI5 = Devices -> Add Devices -> uPnP Devices
Looking at Device Spy or using the My Devices iPhone app. I can see the following ‘devices’ and services in the XML . (It tells me my external IP, upstream/downstream, data usage etc.)
<root xmlns=urn:schemas-upnp-org:device-1-0>
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<device>
<deviceType>urn:schemas-upnp-org:device:InternetGatewayDevice:1</deviceType>
.... Removed....
<serviceList>
<service>
<serviceType>urn:schemas-upnp-org:service:Layer3Forwarding:1</serviceType>
<serviceId>urn:upnp-org:serviceId:Layer3Forwarding1</serviceId>
<controlURL>/ctl/L3F</controlURL>
<eventSubURL>/evt/L3F</eventSubURL>
<SCPDURL>/L3F.xml</SCPDURL>
</service>
</serviceList>
<deviceList>
<device>
<deviceType>urn:schemas-upnp-org:device:WANDevice:1</deviceType>
.... Removed....
<serviceList>
<service>
<serviceType>urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1</serviceType>
<serviceId>urn:upnp-org:serviceId:WANCommonIFC1</serviceId>
<controlURL>/ctl/CmnIfCfg</controlURL>
<eventSubURL>/evt/CmnIfCfg</eventSubURL>
<SCPDURL>/WANCfg.xml</SCPDURL>
</service>
</serviceList>
<deviceList>
<device>
<deviceType>urn:schemas-upnp-org:device:WANConnectionDevice:1</deviceType>
.... Removed....
<serviceList>
<service>
<serviceType>urn:schemas-upnp-org:service:WANIPConnection:1</serviceType>
<serviceId>urn:upnp-org:serviceId:WANIPConn1</serviceId>
<controlURL>/ctl/IPConn</controlURL>
<eventSubURL>/evt/IPConn</eventSubURL>
<SCPDURL>/WANIPCn.xml</SCPDURL>
</service>
</serviceList>
</device>
</deviceList>
</device>
</deviceList>
<presentationURL>http://192.168.x.x/</presentationURL>
</device>
</root>
As this did not work, as planned, I then found the following which @Ap15e did a while back.
http://forum.micasaverde.com/index.php/topic,10220.msg70052.html#msg70052
http://forum.micasaverde.com/index.php/topic,10220.msg69821.html#msg69821
http://forum.micasaverde.com/index.php/topic,10165.0.html
I’ve done what I think I can form the above, but i’ve not been able to see any of the variables, that I could see via e.g intel Device Spy.
Has anyone added a ADSL router (or anything) via the UI and benefited from using the associated uPnP devices and services? (If I go into Automation/new scene/Advanced nothing (no variables) are listed :
