@oTi@:
I have traced and traced and traced; but certainly could have missed something.
In the diagram I posted,
I believe the far “left” switch (front door) to be where the HOT comes in (in fact, that part I do have verified 100%); it then has a set of wires going to the “middle” switch (about 15’ feet away, ‘garage door’)). This is a red/green/ground/neutral set, AFAIK. This was a 3-way switch.
The middle switch is where the old 4-way switch was located, the only thing in that box was the prior 4 way switch, and two sets of cable going in/out - each containing 1 green/1 red/1 white/1 bare/ground. The two whites are wire-nutted together in the back of the box.
The “right” switch (per the diagram) is “upstairs” in a box with 2 other switches. The prior 3 way switch there had a set of cable coming in, presumed to be from “garage door”/middle switch. The wires are red/green/ground/neutral. There is then a single black wire which I believe goes to LOAD.
Again, I have tested all the switches in multiple locations and have had almost the exact same result. 80%. I have also isolated it right now to where I have basically jumped everything (with exception of RED/traveller in my case) from “front door”, to “garage door”, to “upstairs”. Upstairs is where I have the master (NO auxes connected!). As SOON as I connect to traveller (red) the lights only come up to 80% again, even if traveller is capped off at the next known/assumed junction point (“garage door”).
I am 99% this is not a 5 way configuration as i have not seen any other wires that would leave me to believe so, and I don’t think there are any other switches for this circuit that I have discovered.
PS - In my “final” configuration, where should my master “truly” be. At LINE or closer to LOAD? Where LINE comes in (“front door”), as mentioned, “LOAD” only goes to the “garage” (old 4 way) switch box. “Upstairs” has LOAD but no true “LINE” of its own, only if I tie the wires together at “garage”. The only thing about “UPSTAIRS” is it does share a box with two other circuits, which both DO have “LINE”. The difference being, they both are on a different breaker than the “front door” switch so I would assume I do NOT want to take “LINE” for the master switch from a different circuit? (I hope this makes sense in the way I am typing it)
Your response was/is greatly appreciated. I am really hoping to get this sorted out as it’s driving me nuts (and my switch plates are all torn apart!)
