Lowe’s has these switches on sale for $10 dollars off and decided to pick up 5. When adding them to Vera there is no model listed so added as a generic z-wave device. After the install I am trying to find a way to add the parameters to the config so I can configure the ramp rate and steps. But I can’t find anything in the advanced/params that would allow me to do the settings. Based on the their web site these are the options but I just need pointing on the best way of doing the configuration:
. When Receiving a Z-Wave Dim Command
Parameter 7 (number of steps or levels)
Parameter 8 (timing of the steps)
Length: 1 Byte
Valid Values:
Parameter 7 (default = 1) Valid Values: 1-99
Parameter 8 (default = 3) Valid Values: 1-255
2. Manual Control Dimming (pressing the Dimmer?s button)
Parameter 9 (number of steps or levels)
Parameter 10 (timing of the steps)
Length: 1 Byte
Valid Values:
Parameter 9 (default = 1) Valid Values: 1-99
Parameter 10 (default = 3) Valid Values: 1-255
Let us know how these devices work in Vera in general, and in Scenes/PLEG specifically. I have a few switches needing change and I could use a price break if they are sale and working in Vera.
So far these switches are working fine. I was able to change the dimming rate and tested that I can enable/disable the blue LED. They are reporting on/off state. I haven’t setup up any PLEG items yet against them but I did put them into the night mode to shut off and that has worked just fine last night. From what I understand that GE/Jasco switches are polled for attributes by Vera for say dimmed state but are immediately reporting on/off state changes.
I just need some direction on the best way to write some code that can dynamaiclly change parameters of these devices since I also have the GE/Jasco motion swtich where I would want programmaticly turn off the motion or the blue led’s.
[quote=“RonV42, post:4, topic:199207”]So far these switches are working fine. I was able to change the dimming rate and tested that I can enable/disable the blue LED. They are reporting on/off state. I haven’t setup up any PLEG items yet against them but I did put them into the night mode to shut off and that has worked just fine last night. From what I understand that GE/Jasco switches are polled for attributes by Vera for say dimmed state but are immediately reporting on/off state changes.
Thanks.[/quote]
Do your GE switches have a blue LED that comes on when it’s switched off? Were you able to disable that feature if yours do? I think I may have the same switches also bought from Lowes and the blue light is really bright at night. Also I have another thread about trying to make it so these switches will turn off when they are dimmed to 4% or lower but also set the LoadLevelLast to a set level as it remembers the 4% or lower as the last level set so when I go to turn on the switch again it goes to the low level and turns off because of the PLEG command. Anyway, even if I could get the blue lights to just not come on when turned off that would be incredibly helpful.
Update: Never mind about the LED light. I just read how to disable.
