What that document does NOT show is parameter #10…which can be vital. Here are my notes to myself:
“Sync 3-ways” (this is not the real name for this parameter, but I can find no documentation on this parameter) (#10) default is 0. This parameter is vital to the proper operation of master (9540-N) and slave (9542-Z) switches in a 3-way circuit; it only applies to the master (9540-N). If this parameter is set to 0, the switches will stay in sync (that is: both reflect the same state of on/off and dim level) when operated manually; but if Vera is involved, the switches will not update each other when there is a change of state. If this parameter is set to 1, the 2 switches will always stay in sync whether or not the Vera is involved.
- 0 = disable
- 1 = enable
