Simple- but I can’t find the answer anywhere.
Does the GE 45605 require a white neutral wire?
Thanks.
Thanks.
Yes. Page 10 of the installation instructions shows the white needing a connection.
Thank you. I didn’t have the link to that.
Does anyone make a receptacle that doesn’t require a neutral?
By definition all receptacles must have a neutral to connect to the load.
