Picked up a couple of these today and they seemed to work alright at first with a dimmable CFL in the lamps. After turning on load sensing, though, they just won’t turn off from the VeraLite. When I hit off they dim briefly then brighten back up to full, though the VeraLite reports them as off.
Does load sensing just not work on these devices?
Edit: After some experimenting I’ve found that these devices just plain do not work when load sensing is turned on. If variable 29 is set to 1, the devices will not turn off the lamps, even when pushing the button on the module. Set the variable to 0 and it works fine, but then what is the point of having a lamp module rather than an appliance module?
