Hi all,
I tried searching the forum, and couldn’t find much more information relevant to my setup.
Bought a GD00Z-4 Garage door opener from Amazon and am having trouble. Wired it up, and paired it fine. Syncs with Vera UI7 and I can see signals send. However, the door doesn’t move and the device doesn’t beep or flash.
I tried calling Linear this morning, and they want you to pay per minute for tech support, unless you purchased from Lowes and are using their smart home controller (eg not Vera).
In any event, I emailed Linear, but doubt they’re respond anytime soon.
Does anyone know of a comprehensive list of devices not compatible with the Linear GD00Z-4? My opener is from 1998 but it is a security+ model (whatever that means) so perhaps there’s some encryption step that is causing my issues?
My email was as follows:
[right][right]"Am using a GD00Z-4 with Vera3 z-wave controller, and have been unable to get any kind of response from the Linear device.
I am able to pair it to my z-wave controller (one beep, followed by 3 confirmation beeps) without issue. It shows up in my devices list with no issues, and I’m also able to use the Vera app (UI7) to send signals successfully.
However, the garage door doesn’t move. The device device beep or flash lights, or make any indication that it is working.
I’ve verified that the connections are correct.
There are 3 connectors in the back of the garage door opener, labeled “1, 2, and 3”. There are two wall mounted push buttons, each with a pair of wires connected to screws 1 and 2. There are also 2 pairs of wires that connect from the garage door sensors to terminals 2 and 3.
I have the GD00Z-4 wired to terminals 1 and 2.
My security system was there when I purchased the home, so I don’t have the instruction manuals to figure out the model number. It doesn’t indicate a model number on the device itself either, but I can see that it was manufactured in January of 1998. The side label says
“Lift-Master
The Professional Line
1/3 H.P.
Security+”
FCC: ID HBW1127
Can you tell if I have a defective device or if my garage door opener is not compatible with the Linear opener because some proprietary security protocol is being used…?
"[/right][/right]
