So, two years later i want to add some functionality to my GC100 setup and can’t remember at all how i did it
so i start going through the threads to re-teach myself. So here’s the weird part… i show the two devices for my AV components that i created ( a receiver and CD player) that are still on the dashboard (i’m on UI5/Vera3),… and all my related scenes still seem to work. When i look at the device file, it’s called D_Codeset_604.xml.lzo
Pretty sure that’s not what i called them when i created the files.
Second weird thing is that the actual GC100 device is gone from the dashboard? I don’t see it anywhere, even though it’s still listed as an installed app. Has a device number associated with it, but it’s no where on my dashboard.
This leads me to believe that something is not right. Before i go mucking with this, any thoughts? Did some random upgrade occur at some point that deleted/hid somehow the GD100 device, even thought the other two i created remained? where do those devices attach to the GC100 (and it’s IP address)?
??? any help greatly appreciated.
EDIT: quick addition. the GC100 Device and implementation files are still there.
I’m having the same problem. Running UI5 on a Vera3 Unit. I Can’t change the IP of the ITach device in my network. If I do all communication will be lost. Have found a solution yet??? ???
[quote=“tomgru, post:1, topic:194169”]So, two years later i want to add some functionality to my GC100 setup and can’t remember at all how i did it
Had to call tech support to get them to change the IP. They did successfully.
EDIT: quick addition. the GC100 Device and implementation files are still there.[/quote]
Called tech support and they changed the IP successfully. They will send the instructions on how to do so. Might be able to figure out a way to update specific variables to the device using LUUP. I’ll post back.
