Garage Door Plugin
First, let me begin with a disclaimer - this code is to be used for recreational purposes and not to be used for life safety or non-UL/CE listed applications. Use at your own risk, and test thoroughly before leaving unattended.
Attached is the garage door Imp file designed to work with the standard DoorLock dev file. This is designed to work with a HRDS1 or similar battery powered sensor and a ZRF113 or similar relay device. Once you have installed both these devices, note the device numbers. Plug these device numbers into lines 4 and 5 of the attached file (SensorDevNum and ContactsDevNum). Then upload the file to Vera through Mios Developers > Luup Files. Check the box to restart luup after upload. Then, add a new device through Mios Developers > Create Device. Under Description, name your new device. Under UpnpDevFilename, enter D_DoorLock1.xml Under UpnpImplFilename, enter I_GarageDoor.xml, then click Create device. Save, then power cycle vera, and your garage door device should now work like any other door lock.
Not very pretty, but works great. If there is interest, I will clean it up, but it should be a good start for anyone else to clean up… just add a couple lines to the init to populate the status variable - I think that’s what will eliminate the need to power cycle; and maybe add a couple state variable to represent Sensor and ContactClosure device numbers.
Sorry… posted the wrong version… updating now.
Hi Woodsby,
Sounds pretty interesting, but I don’t fully understand what it does?
This basically takes the combination of the door sensor device and the contact closure device on a garage door setup and consolidates them into a single device that behaves as a door lock - in the ui and iphone apps. Locked means garage door is closed; unlocked means garage door is open.
[quote=“mcardenas, post:3, topic:167178”]Hi Woodsby,
Sounds pretty interesting, but I don’t fully understand what it does?[/quote]
If I would have to guess:
The code uses the door sensor to tell whether it’s open or closed, and then has logic based on that to know whether activating the ZRF113 is going to toggle the door open or closed. And that’s all wrapped up in code that can sit under Vera’s (and therefore, SQ Connect and others’) existing GUI.
How’d I do? My question (wiring up the ZRF113s for all three garage doors is a project for this weekend) is whether this is straight-up code that will run on older Vera OSs (and specifically, Vera 1), or does it depend on new libraries or whizbang stuff that has shown up in later versions?
Regardless, I think it’s cool and will avail myself of it as soon as it will run on our active Vera. We have a V2, but have been waiting for the stable update to materialize.
–Richard
I don’t know why it wouldn’t work on a previous UI or Vera 1, but I am running UI4 on both veras, but am not in a position to test on my vera 1 right now. If it doesn’t work on UI2 or 3, I’m sure a slight modification to the luup is all that would be needed. And yes, that’s a correct assessment.
Nice one woodsby!
I’ll install it tomorrow and see how it goes! Should clean up SQ remote a bit as it’ll save having a scene and a status label!
edit
All installed and working great thanks!!
@Strangely, just out of curiosity, did you have to power-cycle vera?
I had to do many things to get it to work as not only did I manage to include a space in the filename of the xml (somehow did this when saving) and it took me ages to work out why it kept on giving me an error when I toggled the lock! But I’d also gotten myself in a knot with the device ID versus node ID, after initially getting it correct, and then changing while troubleshooting the first problem (not known at the time) I’d brought on myself!
Needless to say there was much power cycling and cursing going on. I also wasn’t sure it was going to work as I’m using my alarm systems sensors interfaced through Vera (just integrated it) and even though I could see the sensors tripping, I didn’t have the confidence something wasn’t coded correctly with MCV’s DSC plugin :slight_smile:
Ok, So I have a Genie garage door opener that uses Intellicode.
For my push button in the garage, there are two wires, black and white. Two buttons, door and light we shall call them, and a switch, lock/unlock.
According to the manual, it says if the wall control panel is not connected, the door will not function which leads me to believe that when it is set to ‘lock’ it is just breaking the circuit.
As for the two buttons, i’m not exactly sure how those are working.
In a caution block in the manual, it says “Use of any wall consoles other than the type included
will prevent the light from working properly and could
cause the door to operate on its own”
And for the relevant part, would I be able to use the ZRF113 to operate my door? As long as the light works when the door operates, it’s not a big deal as there is other lighting in the garage.
Mine is a Genie with intelicode; everything works fine including the light. You wont be disconnecting the wall controller… just wiring the local load of the relay in parallel. YMMV though as I have an old model!
So the wall controllers you have still work then? how about the lock? and one last question, with the ZRF113, I would just splice a blue wire into each white & black?
Yep wall controller is still functional also, although I never tried the lock button… cant see why it wouldn’t though, but I can confirm tomorrow!
Not sure about the ZRF113 as I couldn’t get hold of one a while back and opted for hacking an appliance module instead. Looking at it’s PDF I think you are correct and you can either splice it to the existing bell wire (in parallel) anywhere from the motor to the switch… the best place is just attach the wires at the screw terminals at the motor end!
You can wire up the 120V side , then include it, and then check with a multimeter that the blue wires give you continuity when the relay is switched and that it’s isolated from the 120V! If it is then connected the blue wires and hope for the best :slight_smile:
If you are going to use this, then make sure you have a door sensor also and maybe also a camera for double safety :slight_smile:
Just remember that if you cant get @woodsbys plugin to work (or don’t have a door sensor), that you need to create a scene that turns it on briefly then back to off!
Yeah, I was concerned of if it got left “closed” and what that would do, and I was looking at the code for the plugin and see that it continuously checks the status until it is closed and then opens it back up so the circuit isn’t kept closed all the time. I already have plans of putting a camera on the outside so I can see both garage doors as well as the cars when parked in the driveway if I can get it positioned right.
Nice plugin woodsby. Works perfectly for me with my HRDS1 sensor and an outdoor module + power relay combo. BTW, I did not have to power-cycle my Vera2 UI4.
I am setting my garage door up now. Is there an update to the file? Woodsby, I certainly appreciate the work you have done and shared witht he Vera community.
No update - the imp file should run fine on the latest beta (and previous versions). Post back if you have problems. Good luck.
Is there a code you could upload to simply know the status of the door?
Thank you, This is great!
[quote=“burkle3, post:18, topic:167178”]Is there a code you could upload to simply know the status of the door?
Thank you, This is great![/quote]
Not sure I understand the question but…
You just need a door/window sensor such as a HRDS1 for that which will show you the status of the door . You would need the sensor anyway to also make this plugin function correctly!
Is there anyway someone can upload pictures of their set-up for this? I really want to get this done but am a little nervous starting this project as I am not exactly sure how everything is hooked up and put together. I would really appreciate it if someone can do this.
