I Have followed the instructions for the Garage Door Plugin. I’m using the aeon door/window sensor, Global Cach GC100-WF2CC like they show in the instructions. I have loaded the GC-100 plugin, and then the garage plugin. The gc-plugin installed itself as four devices one as the parent device and the 3 others as the controls for the 3 relays on the unit. the aeon sensor showed up fine. The problem is when you go to use the Unlock / Lock buttons it starts fine except it leave the GC100 circuit in the close state and never releases it. So the work around is you have to go to the device created for that specific contact closure (the gc-100 unit created three). and select off. the Plugin starts the garage door via the GC-100 but never releases it. (like pressing the button on the opener and not releasing it.) so I have to hit unlock on the Garage Door Device and while the garage door is opening I have to go down and select off on GC-100 relay button that is connected to the garage door (the unit has 3 ) Is there any way to make it automatically shut the relay off after making an unlock/lock condition.
Thanks for you help.
