Hello All, I am very new to Vera and try as I may I can’t figure out how to get Vera to notify me if the garage door has been left open for x amount of minutes. I’m using the mimolite with the flair magnetic door sensor hooked up to the mimolite. I can set the plugin to notify me if the door is open or closed but not after it has been open for a period of time. I figure I’ll need to create a new scene with Lua code but I don’t even know where to begin. if I knew the command to find out the state of the sensor that is attached to the mimolite, I could put in a delay and if the door is still open send out a notification. However i’m not sure how to do this…but what a marvelous (sp?) way to learn.
Any assistance would be appreciated.
