Hopefully this helps someone. Here is a step-by-step on what I did to get my Foscam working. Haven’t tackled motion sensing yet. I realize there are numerous threads on this, but that’s the problem, there are numerous threads on this and I had to jump back and forth and use bits and pieces to get everything working. I’m using the latest FW versions for my particular hardware at the time of this writing.
Foscam FI8918W - FW 11.37.2.59 / Web UI 2.0.10.14
Vera Lite - FW 1.7.513
- Download I_FoscamPTZ.xml file from here
http://forum.micasaverde.com/index.php/topic,8832.msg68515.html#msg68515 - Open the I_FoscamPTZ.xml in a text editor and modify it per the following here
http://forum.micasaverde.com/index.php/topic,14820.msg167496.html#msg167496 - Save to desktop
- Devices > add device > security cameras > ip camera (generic ip camera) > next > next > manually install the camera
- Add name
- Camera type > other IP camera
- Find your corresponding URL here based on your camera model
http://www.ispyconnect.com/man.aspx?n=foscam
Paste the following into the box directly below Other IP Camera (replace IPADDRESS, USERNAME, and PASSWORD)
http://IPADDRESS/snapshot.cgi?user=USERNAME&pwd=PASSWORD&count=0 - Fill in username and password > Choose a room if applicable
- List network devices > click on add next to the ip address of the camera
- Next (click cancel if prompted for credentials > proceed even if there isn?t a thumbnail)
- Next > Live view may be operational (even if it isn?t, proceed with the next steps)
- Click on cameras on the left menu
- May see a spinning wheel or a thumbnail (if you don?t see a spinning wheel or thumbnail, click on cameras on the left again)
- Click on thumbnail or spinning wheel
- Settings
- Modify following if needed: Device name, Assigned room, IP, Port, Username, and Password (port is probably the only field missing)
- Check off any applicable lights
- Save
- To add pan and tilt go to Apps > Develop Apps > Luup Files > Ensure Restart Luup after upload is checked > Upload > Select the file created in step 3 > Done
- Go back to Cameras > Click on the camera thumbnail (thumbnail may not have a picture, proceed anyways) > Settings > Advanced settings > Params tab > Where it says impl_file, paste I_FoscamPTZ.xml > Click out of the box to save
- Variables tab > In the Commands field, paste the following
camera_full_screen,camera_archive_snapshot,camera_up,camera_down,camera_left,camera_right,camera_preset
- Click out of the box to save
- Go back to Cameras to see if everything is working (if not, verify that URL, impl_file, and Commands are properly filled in)
If URL, impl_file, commands, or anything for that matter, is not saving properly, re-add the value in, click out of the field, click back, change the room, save, change the room back, save. Ever since I?ve been on this FW, clicking out of the field doesn?t necessarily save.
