Foscam issues in VeraEdge
I have 4 Foscam Cameras, 2 SD cameras, and 2 HD cameras.
For the 2 HD cameras, both of these cameras were originally detected by Vera, but neither would work. I had to delete the original cameras that were auto-detected. I followed some guides where I was able to utilize the special implementation file and implement the generic ip camera in there and I created the two new cameras that are working. The picture and video shows up, ultimately they look like they are working. Vera on the other hand is reporting an error saying that it “Can’t detect device”. Anyone know why this is happening?
For the 2 SD cameras, I did reply in the Foscam Plugin thread, but I thought I’d use this to ask if anyone has been able to get the SD cameras from Foscam to actually work on VeraEdge. If so, how?! Right now, I cannot get either SD camera to work. The URLs I am utilizing have been verified to produce a snapshot and motion jpeg.
Checking to see if you got the foscam cameras working with Vera edge? I’m trying to decide on which cameras to buy - and cannot decide…
Do these work now? What did you have to do?
Thanks in advance!
I was unable to get my Foscam camera to work with VeraEdge. They work fine in Vera2 IU5. When I tried to install the plug in it just gave me an error. I tried to manually config it based upon my IU5 setting, but no luck.
