Hello,
I have had my Vera 3 for a couple years and been very successful with adding other cameras - Two (2) D-Link DCS-932L cameras and a Foscam FI8910W. Recently the Foscam stopped working (red steady power light only with no startup motion or wireless activity), so I replaced it with an FI9816P model. I was able to successfully add it to my network through the Foscam setup and can see it in a browser window at:
http://:/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=&pwd=
However, when I try to add it to Vera 3, I get the “Unable to get image from your camera” error message. I’ve tried this method initially:
- Click Devices > Add Devices.
- Click Add next to “I want to add an IP Camera”.
- Since it doesn’t show up, in the list, I click I want to add “Manually add”.
- After locating the Foscam’s IP address, click the corresponding Select.
- For type of camera, I select “Foscam Camera”. The URL populates with “http:////snapshot.cgi”
- Enter Username (for Foscam)
- Enter Password (for Foscam)
- Click Next.
The next page displays the “Unable to get image from your camera” error message.
I have tried the suggestions that have worked for others (i.e. eliminating one of the “/” in the snapshot URL, creating a device, using the path “http://:/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=&pwd=” in the snapshot URL, using a Generic IP Camera under type of camera, etc.), but had no luck.
I’m running the latest firmware for both. Vera 3 UI5 is at 1.5.622 and the Foscam FI9816P is at System Firmware Version 1.9.2.12 / Application Firmware Version 2.51.1.38. Under Apps, I have installed the Foscam IP Camera 2.6.
In the event this is a camera-specific issue, I searched for “FI8910W”, but found nothing in the forums and really nothing of value via Google. I’m willing to retry some of these other suggestions in the case I have done something incorrectly. Any help is greatly appreciated.
Thanks,
Joe
