Does anyone know if a Foscam outdoor camera (which is currently connected to a Foscam NVR) is compatible with Vera to be used as a motion sensor?
The camera is connected on the same IP network as the VeraEdge and is ONVIF compliant.
I can view the camera from my computer via a browser. If that information helps.
Basically I want an inside light to turn on when motion is detected and then turn off after motion stops for a minute.
Thanks.
