Hi, has anyone tried the Fortrezz Zwave WV-FZ auto shut off valve (for a water pipe)? Or the corresponding WWA-01 water sensor? Is this something brand new? I’m not finding it for sale anywhere, just mentioned at the fortrezz site.
Anyway, Just wondering if it works with Vera in general.
I want to try out 2 valves in conjunction. One to turn off the water, the other to open the line to drain the water. And a third trigger to turn off the power to the heat tape wrapped around the pipe. Wonder if that will work out?
This would be used for Freezing conditions. I’m assuming one device can trigger another (haven’t tried that yet). For example, a Zwave temperature sensor or the above mentioned moisture detector could shut off the water and open the drain line.
