Everything is in the title. With this device, you can use a battery or a power adapter. I’m using a power adapter and want to be sure that this device operate as a zwave relay, I mean it can repeat the zwave signal to others units. How can I check this? Can I force this behavior with a parameter? Thanks.
Any luck with this? I have the same Q.
Documentation on all Z-Wave devices say as a thumb rule, if device is not battery operated it is repeating any z wave signal.
However, I am not sure if it does by default, do we need to turn this feature on, or if it is even configurable.
Would love to know how to learn about the z wave routing in my network.
