How does one go about setting up associations btwn the Fortrezz valve and the sensors? Scenes don’t seem possible either as the sensors don’t show up as triggers.
The valve and the sensors are all included in Vera’s network and work individually; ie can turn the valve on and off, and the sensors report temp and alert with water when tested.
I have configured the individual sensors to send alerts in the event of a water trigger via Vera, but can’t seem to set up an event that would trigger the valve to react from a WWA event.
I am using the device file D_TempLeakSensor1.xml for the WWA’s, and the valve is configured with D_BinaryLight1.xml (this seems wrong but does support On/Off). Is there an updated/different LUUP file that I should be using to make the associations possible?
[quote=“jsed, post:1, topic:167498”]How does one go about setting up associations btwn the Fortrezz valve and the sensors? Scenes don’t seem possible either as the sensors don’t show up as triggers.
Any help much appreciated![/quote]
Hi jsed
Specifically what water sensor are you using? I’m using eight Everspring ST812 to trigger the Fortezz shutoff valve. It works almost instantaneously.
Z
