Hello,
First of all, let me say that you did a great job with Veramate, the App is spectacular from a design point of view. I can customise any way I want. Super.
I have installed it on multiple devices, but where is shine is on an old iPod, I have built a frame and I use it as home controller. This has the wow factor.
Let’s go to the issues. I have 2 in particular:
The App connect via cellular instead of WiFi. Of course the iPod has no cellular, so when it say cellular I am assuming that it connects to the remote server. In fact there is a 2 sec delay when I turn on/off lights, while the vera app does not have this delay.
I also tried guest mode: with this mode I am directly connected via WiFi (confirmed via Vera Box section) and there is no delay at all. Obviously this mode for me is not possible since I loose the ability to sync via google drive configurations/icons/positions across devices. -
The second issue (related to the first) is that on my iPhone I was experiencing continuous loss of services, long delay connecting, and when I was turning on/off a light nothing was happening. Also the iPhone was always using cellular instead of the local WiFi. I decided to reset the App, and now I am not able to connect at all (only guess mode works). I am attaching a screen shoot.
My Asks:
How do you decide if you need to use the cellular (I think you mean server mode) or WiFi? Can you have a setting that forces WiFi?
A quick fix could be to have something like guess mode that recognise the serial number and allow me to load/sync configuration based on the serial number. Right now when I am in guess mode the serial number is the ip address of the unit, and not the actual serial number. Also the name is “Remote Vera” and I do not have the ability to change it.
Maybe you can make the serial number and the name editable to allow config sync -
Please fix the fact I cannot login anymore from my iPhone after resetting the APP. My iPod is still connected using the server.
I have the latest App installed and in my vera account I have registered 4 Veras in 2 different homes.
Kind Regards
