Hi!
If i update the firmware on a RFXtrx433E via a PC. Can I after the update plug it back into Vera and everything will be as normal?
Is all my devices and settings still in the Vera?
If you are updating with the same type of firmware (Typ1, typ2, ext, ext2) then everything should work just as before.
