Hi, Frasier!
I made significant progress with the Aeon Home Enegy Monitor Last night! (Sadddd Man that I am!)
Just wanted to share my findings with you. I cannot take the credit for the idea as i saw it somewhere else in these forums, and cannot find it again!
Basically, with a Vera 3 UI5 and a 3 clamp HEM running V.3.67
Spanner icon on the HEM itself, not a clamp. Device options tab, Set variable 3- Enable Delta to 0
Set variable 101-Report 1 to 2316
Settings, Configure node right now
This makes the HEM itself and Clamp1 report pretty much real time Watta and KWH with no values that stick!! So far it is working a treat and I can see the boost when i put the kettle on after a maximum of 30 seconds, as that is still the reporting interval.
The trick is that setting parameter 3 to zero turns off this stupid delta function, which is too complicated and “faffy” ! So, the HEM is basically reporting whatever you have told it to report evry reporting interval. Simple & straightforward!
The parameter that goes ino variable 101 took me a while to get my brain around though! You need the Z-Wave definitinion file from Aeon themselves which you probably have anyway but i have enclosed it here. I don’t know what your hexadecimal & binary maths is like, but here’s my rendition of it!
2316 decimal = 90c hexadecimal
Since variable 101 (reports to send in Group 1) has to be encoded into 4 bytes as dictated by the definition, then the full hex no is 0000090c since each hex digit fits into a nibble, or half a byte, or 4 bits with the Most Significant Bit first.
Therefore:
9 means set Configuration Value 3, Bit 3 high = Auto send Clamp 1 KWH & set Bit 0 high = Auto send Clamp 1 Watts
0 for the reserved top nibble in configuration value 4
C means set Configuration Value 4, Bit 3 high = Auto send Whole HEM KWH & set Bit 2 high = Auto send Whole HEM Watts
Sounds complicated but it’s not really when you see how it works!
So far, working great! Recommend that you try that!
