I’ve upgraded, but Vera isn’t working. I can connect manually to its ip address and get the following:
Checking internet connection …
Loading system database …
Loading timezones.json …
Loading local database …
Loading sysinfo …
Sysinfo loaded
Internet check status: ok
timezones.json loaded
system database loaded
Cannot retrieve user data.
I have MCV looking at my unit remotely now.
Back online now. Thanks MCV.
Upgraded to the 1.0.423 firmware with no issues.
The problem was that in the prior conversion of data from .320 to .404 there was some legacy data about old devices, and in .422, the new ‘active scene’ highlighter didn’t like this. I posted .423 which correctly handles this.
I have spend more than 3 hours waiting for the upgrade to 1.0423 to complete… Not able to know the status of and don’t dare to switch to other works, worry it might crash vera again. Shall there be any indication of the firmware upgrade status! Notice the 1.04… firmware take enormous time to upgrade compare he 1.03…!
Upgraded to 1.0.423 with no problems, so far…
Thanks for this Christmas gift
Upgraded to 1.0.422 and that went well. Setup a username and password and checked “require for local network”. Now Vera asks for a username and password and will not accept the username/password entered, or any other. Has anyone else run into this?
