Findvera.com login failed
I have my vera2 working with access from LAN. I can also access it from Iphone, both 3G(via internet) and via LAN using Ivera APP.
But when accessing using findvera.com I get the “login Failed” error (plus a general comment (Vera not found on your home network).
Also getting a “500 - Internal server…” error accessing via UI4, network and Advanced configuration.
I have also performed the Network Troubleshooting without error.
It is configured as Switch
I have tried configured with DHCP and Fixed IP, same result.
I can access my account via mios.com and can see my Vera device with the right IP address.
Simply can’t get findvera.com to accept my login.
Any help?
If you are running U14 your access is through mios.com not findvera.com.
You should use https://cp.mios.com, as something seems to be wrong with mios.com’s SSL certificate …
Then access your system via ‘MiOS Systems’ → ‘Dashboard’
Thanks very much - I just followed the instruction with the new Vera2 just arrived. THANKS
