Is Fibaro new Walli compatible with VERA? If yes which ones are please?
And the most important question, has anybody tried it, what was the feedback?
They are saying it is the same devices but the difference is the form factor, i will try to order some today and see if they are compatible. i will update the info once i install and try them.
I look forward for these as well. They seem like a solid solution for EU users.
However, I think that, as with all basic on/off switches, this should work out of the box with Vera, minus the advanced features.
Hello, I finally tested the fibaro Walli switch, what i like about it:
What i don’t like:
Edit: there is a bad thing about Walli which is the switch itself, the plastic frame that you need to fix in the electric box is made out of soft plastic that can bend, the problem with that is that if you have the slightest bend in this frame, the on/off switch will not work properly, either up or down buttons will not work, it is not easy fixing it to the wall because of that
overall i think it is a very nice switch, i have to try the dimmer and the roller shutter, but i think they are pretty much the same.
Hi Shady,
Did you try other walli product on your Vera?
What’s your UI firmware version
Thanks a lot for your feedback!
Hello @cwoessner, yes i tried the dimmer and the roller shutter, they are basically the same as the fibaro switches but with a face-plates now. the LED colour is very nice, and if you are ok with the white colour then they look great
my biggest issue with the Walli is still the quality of the inner face-face plate, it has to be adjusted many times so they switch will work normally otherwise it will get stuck and you can’t operate one of the switches (Top or bottom switches). but please remember that I have UK wall boxes and the walli comes in European face-plates, so that might be the issue too.
I see on Fibaro French forum that they have the same quality issue as you mention… Since end of september Fibaro do a new batch of product and new product doesn’t have this problem anymore
I suggest you to get intouch with your dealer to change your device for a new one !
