I have connected that device to Vera Edge - Vera don’t have native support for FGWPF-102,only for FGWPF-101.
So - its works - but I can see only current power - but accumulated power not. I have try install by Generic Z-Wave Device - same thing.
Any ideas?
Thanks for answer. Maybe i have asked not corectly. I need to show energy consumption in kw/h. when i add device its make 2 devices - one with switch and current consumation,and second - used energy power - but second dont show nothing.
cabrion, I see, so you want both W and KW/h reading showing at the same time on the device ?
I’m not totally sure but I think this should be possible if it can be enabled on the device itself, through configuration parameters. These should be defined in the device manual.
Same problem here. Instelling the device shows afterwards 2 devices. One on/0ff switch and an unknown device (power meter) Any solutions ? The switch is werking fine but not any possibillities with the power meter.
I have a similar case. Mine created three devices. One with a power switch and current watt consumption, another with just a power switch, and a third that doesn’t have anything…I don’t know what the heck the third one was supposed to be. Why can’t it be one device…or at least one with a switch and the others with different/various statistics?
I just installed such FGWPEF-102 and have the same issue/question.
Parameter 15=1 is for measuring energy consumed by the Wall Plug itself according to the guide.
Regarding the 2nd device: power meter. Has somebody made progress on that or is there some information that has been shared?
I understand that there are 2 devices installed: one is a switch and the 2nd is a power meter. (This is also the case with a smoke sensor that has a built-in temperature meter: also 2 devices). But the power meter should report something.
