Hello ,
I installed on my garage door 2 reed switches on an universal sensor from Fibaro.
But the input is wrong on one of them. They are both “normaly open” ( had to change parameter 3 and 4 in 0).
I want one of the sensor the reverse the state , when I got now a running red man , I want it to be green and non moving.
Is there a way to change it with a parameter? or do I need to get another reed switch (normally closed) , if I need another one , can I mex them , 1 NC and 1 NO?
Thanks,
Cor
