I am new to Vera, so please excuse possible stupid questions
I setup Vera Plus and then added successfully Fibaro Wall plug with no problem (already existing in the devices list)
Then I tried adding Fibaro Universal Sensor which is connected only to a DS18B20 temp sensor (cabling rippled checked).
The device was not in the device list so I added it as a generic Z Wave device.
Then I got 3 new devices: 2 Binary sensors and one Universal sensor.
I suppose that the universal sensor is the temp sensor (or am I wrong and this refers t the module itself and not the temp sensor attached which is not added at all?)
I cannot see how I can get the temp reading from the sensor.
I noticed that in device settings all 3 new devices are mentioned as motion sensors.
Reading this Stylish and environmental smart home design & build I changed ‘device_file’ entry to 'D_TemperatureSensor1.xml (in the universal sensor device) but no luck.
Thanks in advance for your help.
PS If there is a link with general instructions for similar setup issues, please let me know.
