Alarm broadcast
A value other than 0 means that alarms are being sent in broadcast mode, i.e. to all devices within a Fibaro Smoke Sensor?s range.
Available settings: 0 - 3
0 ? broadcast inactive
1 ? SMOKE ALARM command broadcast (2-nd & 4-th Association Group) active; casing opening notification broadcast (3-rd & 5-th Association Group) inactive
2 ? SMOKE ALARM command broadcast (2-nd & 4-th Association Group) inactive; casing opening notification broadcast (3-rd & 5-th Association Group) active
3 ? SMOKE ALARM command broadcast (2-nd & 4-th Association Group) active; casing opening notification broadcast (3-rd & 5-th Association Group) active. Default setting: 0 (broadcast inactive)
Parameter size: 1 [byte]
Alarm broadcast
Parameter size: 1 [byte][/quote]
No is has not. A fibaro smoke sensor cannot be remotely activated (function controlled). The parameters you are reffering to is to trigger to a contoller or other zwave capable receiving device.
