Hi
I have installing Fibaro Roller Shutter 2 FGRM-222 on Veralite and it is working fine but it show the error Failed at: Setting user configuration how can I fix that error
Thanks for all
Hi
Thanks for all
And The Shutter is opens of his own without give him any order
Please post a photo of the Device Options tab from one of your shutter modules.
Thanks for reply
Try 1 Byte dec, save, reload and check if the error is gone.
Thank you Kullematz
I did this and the same error
What is if you delete your Configuration Setting (variable 29) completely?
Thank You Very Much
Now it is Ok, when I delete variable 29
Thank You again
I am circling back on an old topic: I have 12 Fibaro FGRM-222 working properly, more than two years, but now, one of them, presents “Setting User Configuration”. It works well but I can delete the notice.
The only parameter I can see is the number 1 without any value.
Already solved.
I removed the parameter 1 because it was the only Roller Shutter I had with this parameter. Then, I went to “Comands” in “Advanced” and activated “Configurate Node Now”. The problem was fixed.
