Is anyone successfully using the Fibaro RGBW Controller 2 ?
I installed mine with 4 white LED strips and it’s created 10 devices (6 dimmable lights and 4 sensors).
While it works, there does not seem to be a single device (node) I can use to control them, it requires a combination to be on ( dimmable 1+2 on and then dimmable 3 can then work as the light slider?
There are also a number of Generic Sensors that we’re created - no idea why ??..
I have a ticket logged with support for this, but I’m wondering if I’m the only one who has seen this ?
I’ve excluded and re-included it multiple times, but still the same.
Attached is a photo of how it’s currently installed, I’ve tried it on R and W, same result, the choice of colour seems to relate to the Dimmer Switch # that has to be included for it to come on…
For example ..
When wired into R (OUT1) it needed _Dimmable Light, _Dimmerable Light 1 and _Dimmerable Light 2 to all be on for it to work
When wired into W (OUT4) it needed _Dimmable Light, _Dimmerable Light 1 and _Dimmerable Light 5 to all be on for it to work
Hello @parkerc,
I’m sorry for the late response, we made a retest of the device and understood that it was broken, so we had to spend more time, waiting to get a new one.
As I understand, you need to use this type of connection(not sure is it the same as on the png that you sent), for single color is it like this?
Also, we connected it to the IOS system, it shows 5 controllers(R, G, B, W, and main one) and it doesn’t show any sensors that you mentioned.
Can you please tell me which exactly platform are you using and what is your firmware version is?
Hello @parkerc, if I understood you clearly you should use this type of connection if you want to connect just one LED strip, earlier you mentioned that you want to connect 4 white LED strips, but it is fine, on our side we are trying to investigate why you have such visualization of devices in the list.
Sorry for any confusion, my first post was quite a while ago, but to keep things simple, i have single colour white LED strip running off of one connection on the Fibaro RGBW 2 module, and checking the diagram again, I believe I have that implemented as expected…
Looking forward for further updates on this, as i agree it’s strange to have so many nodes/devices added.
