Afternoon
I have installed this relay without a issue inti vera but having a problem in vera with it.
Does let me doing the following:
Turn light off or on
Move the device to another room
Rename the device
The light works without a problem with the switch as normal
Regards
Rich
Although you stated the opposite, I now assume that you meant to say that you are unable to control the Fibaro from within Vera and you are unable to change the device within Vera.
If you cannot even rename the device in Vera, it is likely a Vera problem. I would exclude the device from Vera. Make sure it is gone. Then include it again.
Hi
My mistake. I have managed to rename it and move to correct area.
Cause there is 2 devices gets added i kept looking at the 2nd one that wasn’t changing or moving
