Fibaro MultiSensor 3in1 FGMS-001 - temperature reading setup
Hi
First I want to say hello, as this is my first post on this forum ;D
And right away I need your help. ???
I have two Fibaro sensors FGMS-001 from which it looks like I can read the values correctly, already checked by Vera Support team, but it looks like parameters are set in the way that only when temperature will change more than a 1 celcjusz it will triger change. To what I manage to learn is that there is parameter called:
“TEMPERATURE REPORT THRESHOLD (Parameter Number 60, Parameter Size 1) parameter determines the change in level of temperature resulting in temperature report.”
Coudl you please advise me how to read the present value of this parameter and how to change it to e.x 0.5C ?
thanks for all your support!
