Hi
Just got the new fibaro motion sensor (gen 5) is there a way to set the sensitivity of the motion in the vera controller?
Hi
goto /device/Device Options/Configuration settings/
click on ‘add configuration settings’
Enter:
Variable=1
data size=2 byte dec
Desired value=?? (per below)
parameter 1. Motion detection - sensitivity
The lower the value, the more sensitive the PIR sensor is.
Available settings: 8-255
Default setting: 15 Parameter size: 2 [bytes]
This can be found in the manual page 12:
Thank you!
