Hello, I have a scene which will turn on all the lights if the sensor detect motion, problem is when I arm the sensors with another scene it turns on all the lights…not a massive problem but I want to add sirens to the scene so I really dont wan them going off when I arm the sensors anyone know how I can stop this?
thanks
Then I guess you have to change the trigger in your scene into something else, I guess you have several choices while creating the scene like below ? Why not take “when sensor detects motion wheter armed or disarmed” ?
Whenever Sensor X is armed and detects motion
Whenever Sensor X is armed and stops detecting motion
Whenever Sensor X detects motion whether is armed or disarmed
Whenever Sensor X stops detecting motion whether is armed or disarmed
Battery level goes below
Whenever Sensor X is being tampered with
And then make a separte scene with the lights AND sirenes, but then choose the “whether sensor is armed AND detects motion”
Hello Thank you for the reply, I’ll give it a go
