Hi
I have a Fibaro Motion Sensor FGMS-001 v3.2 I am trying to set up a group 2 association with a Fibaro Dimmer 2 module in my Kitchen.
The Motion Sensor is included in to Vera OK and also securely I believe, as it says exchanged security keys.
The Dimmer 2 module is also in secure mode.
When I try and setup the association group I am unable to configure the motion sensor, it always gets stuck on “Setting User Association”.
I have tried unpairing and repairing the motion sensor. I’ve tried resetting the motion sensor back to factory. I have even restored a Vera backup and the Z-Wave network from yesterday.
No matter what I try its not working.
I am seeing this in the log file.
got CAN <0x75f70520>
01 02/11/20 15:50:26.744 ZWaveSerial::Send m_iFrameID 227 type 0x0 command 0x13 got repeat failure 24 iNumFailedResponse 1 time 78744 start time 78715 wait 2000 m_iSendsWithoutReceive 0 <0x76370520>
01 02/11/20 15:50:26.788 got CAN <0x75f70520>
01 02/11/20 15:50:26.788 ZWaveSerial::Send m_iFrameID 229 type 0x0 command 0x16 got repeat failure 24 iNumFailedResponse 1 time 78788 start time 78759 wait 2000 m_iSendsWithoutReceive 0 <0x76370520>
01 02/11/20 15:50:26.788 ZWaveJobHandler::SendDataAbort failed <0x76370520>
01 02/11/20 15:50:26.789 ZWaveNode::GetNonce node 90 cannot send request, abort (nil) <0x76370520>
01 02/11/20 15:50:26.789 ZWaveNode::EncryptFrame m_iFrameID 226 cannot get nonce node 90 command class 0x85 command 0x1 <0x76370520>
02 02/11/20 15:50:26.789 ZWaveSerial::Send m_iFrameID 226 type 0x0 command 0x13 sent ok - can’t encrypt <0x76370520>
01 02/11/20 15:50:26.789 ZWJob_SendData::Run done/fail job job#18 :assoc set 90grp 2 dev:409 (0x2bdb740) N:90 P:13 S:7 Id: 18 took 88 ms method 2 to node 90 command 133/1 failed 5 retries 0 of 0 <0x76370520>
01 02/11/20 15:50:26.790 ZWJob_SendData::Run job job#18 :assoc set 90grp 2 dev:409 (0x2bdb740) N:90 P:13 S:7 Id: 18 to node 90 command 0x85/0x01 failed 0/0 or Quit 0 <0x76370520>
01 02/11/20 15:50:26.790 ZWJob_SendData::JobFailed job#18 :assoc set 90grp 2 dev:409 (0x2bdb740) N:90 P:13 S:7 Id: 18 Priority 13 <0x76370520>
02 02/11/20 15:50:26.790 ZWJob_ConfigureNode::ChildChanged aborting job#4 :conf_jh#90 dev:409 (0x18bb2a0) P:14 S:5 Id: 4 for job#18 :assoc set 90grp 2 dev:409 (0x2bdb740) N:90 P:13 S:7 Id: 18 <0x76370520>
04 02/11/20 15:50:26.791 <0x76370520>
02 02/11/20 15:50:26.791 Device_Basic::m_eConfigured_set device 409 was -2 now 0 zw aborting <0x76370520>
06 02/11/20 15:50:26.792 Device_Variable::m_szValue_set device: 409 service: urn:micasaverde-com:serviceId:HaDevice1 variable: Configured was: -2 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0x121dcd0/NONE duplicate:0 <0x76370520>
04 02/11/20 15:50:26.793 <0x76370520>
04 02/11/20 15:50:26.794 <0x76370520>
01 02/11/20 15:50:26.794 ZWJob_SendData::Run job job#18 :assoc set 90grp 2 dev:409 (0x2bdb740) N:90 P:13 S:3 Id: 18 device 409 node 90 Aborting without requee after 0 retries <0x76370520>
01 02/11/20 15:50:26.864 got CAN <0x75f70520>
02 02/11/20 15:50:26.864 ZWaveSerial::Send m_iFrameID 231 got a CAN – Dongle is in a bad state. Wait 1 second before continuing to let it try to recover. <0x76370520>
Anyone know how to fix it ?
