Hello
I use a FGS221 to replace breakers … and be able to set it with my vera 3
so I only got monostable buttons…
I tried tu use the first one…
The vera part is OK, but the push button do not act as wanted …
It acts just like the buttons are bi-stable … :
How do I tell de FGS221 that I am using monostable buttons ?
Welcome!
Go to the parent device of the FGS221. Select the device options tab, then select ‘Add Configurations setting’. Enter parameter ‘14’, then select ‘1 byte dec’ and enter ‘0’ for the desired value. Then close the control panel and click ‘Save’. Give Vera a minute or two to ensure the settings are written to the device (you can re-open the control panel to check). Once that parameter has changed from ‘1’ to ‘0’ your pushbuttons should work ok.
I’m in UK, so using the EU frequency for Vera (lite) and Fibaro devices that work well together. Sorry I don’t know what other frequencies are available.
I am using veralite ui5 with dimmers and relais from fibaro and have no problem
Only observation that the relais works not very smoothly with led lights
If a normal halogeen is fitted they are good
