Fibaro FGS221 associations don't fire when switched from Vera?
I’ve associated channel 1 of a FGS221 with a plug-in switch, using association group 1 (channel 1 state, binary). When I toggle the physical switch on the FGS221, the plug-in follows the channel state, but when I change the state of the FGS221 channel from the Vera, nothing happens to the plug-in. ???
Does anyone know whether that’s intended behaviour of the Fibaro (a bit odd and rather unhelpful in my view if so!), some lesser-known parameter that I need to set or another “quirk” of Vera?
Thanks!
Associations on all devices fire as a result of the device being manually triggered and not when controlled by Vera.
If you need to control the secondary device as well then you need to do that from Vera too.
