Fibaro FGS214 and FSG224
Hi there, I was wondering if there is any info about the compatibility of those 2 new switches from Fibaro.
Thx
Hi
tested yesterday the fgs224, it does not work, only one controllable device
I suspect it’s like the new Fibaro devices: no luck. You could try to pair as generic and see if at least channels are recognized. I could help, it should be MultiChCapabilities to be written by hand.
Hi
I need to put it back on EzloPlus so the team can see.
On EzloPlus there are 3 devices and on VeraPlus only 1 but it works in switching
Can you explain the MultiChCapabilities to me please? is it the CommandClasses?
At least on VeraPlus I can use the web interface while on the Android app I can simply do nothing
Hi
by restarting my Vera plus yesterday the second child device appeared, I can order but I have to check with the multimeter tester that it works correctly. I keep you informed of the progress of the tests
Sorry, I forgot to reply. MultiChCapabilities should maps CommandClasses to children. Here’s what a Fibaro FGS 223 reports:
1,16,1,94,134,37,133,89,142,50,239,38,
2,16,1,94,134,37,133,89,142,50,239,38,
Here’s Qubino Switch 2:
1,16,1,94,133,142,89,39,37,50,
2,16,1,94,133,142,89,39,37,50,
It’s vital to route commands and status from the master to the children.
Hi
Thank you I will look at it
Hi
I did the tests last night, it works, following inclusion a master device appears and controls the Q1 output, a child device for Q1 and a child device for Q2.
I would put the MultiChCapabilities tonight
Let me know it works and I’ll add it to my scripts on GitHub to support non-supported devices.
@therealdb I feel like I lost few topics not reading this forum daily anymore. Can you pls share the link to your github scripts?
Ciao
ciao @Domoworking,
I have started collecting them in vera/Devices at master · dbochicchio/vera (github.com)
Hallo,
What can I do with this two files? How to implement?
Kind regards
We cannot find this device listed for sale either on amazon. Can you please provide a link where we can buy it?
(Any device requested for integration should be commercially accessible).
Thank you,
Ezlo Integration Team.
