Fibaro FGS-223 - primary switch E1 stop to work - driving me crazy
I have huge problems with FGS-223 to properly cooperate with Vera Plus.
Immediatelly after inclusion process, device works perfectly.
After 2 or 3 days, the primary switch stop to physically control the power in the socket. In Vera everything is correct - no any “Can’t detect device” or others.
However, after switch on/off nothing is happening. I am using this to control the wall plug. No any manual switches connected to S1/S2.
What is interesting, secondary switch E2 works OK.
Does it mean that device is broken?
How to troubleshoot it?
Does anyone experience similar behaviour, because so far I have only one solution - hammer :slight_smile:
Hello there,
Latest beta should address the Fibaro FGS 223 issues.
http://support.getvera.com/customer/en/portal/articles/2909666-ui7-▾-vera-beta-software-update-▾-version-7-0-24b-1-7-1006-1-7-3422-1-7-3423-1-7-3424-▾-december-11-2017
If Beta word is discouraging, we should have the full version out before Christmas.
OK, thanks,
My case is a little bit unusual, because it is related to primary E1 switch, not secondary E2 switch.
Hopefully it fix this issue as well.
It looks for some hardware issue - upgrade did not solve the problem. I can here the relay switch sound, but the power is still ON.
223 is on the way to warranty service.
I had to send back a unit, but E2 was the culprit in my case. overall I like them.
After the latest vera plus update (a few days a go), both of my 223’s no longer work reliably.
They both fail to configure, and are super slow to respond, if they even respond at all.
The only improvement I see with these devices is channel 2 now reports wattage.
Over all, since this latest update, my controller is simply unstable - I am assuming this is due to the 2 fibaro switches that fail to configure.
I opened a ticket with vera the same night (I think it was the 20th) and haven’t heard back.
Crickets!
with verasecure running 7.0.24 it should work, i’ve tested it with 7.0.25b sucessfully
