Hi, after some interventions of Vera Support unfortunately it did not seem possible to remove the “Getting Secure Class” error message from the Fibaro FGS-223 EU v3.3 (and that is important because I have other v2.x device that work and do not display this)
I’ve paired the unit straight on the Veraplus, so distance cannot be a problem.
What kind of sorcery would it take for a Vera Plus to correctly recognize this ?
The good new is that the Q1/Q2 “channels” effectively work, only the top-level “Scenery Controller” device keeps indicating its getting “Secure Device Class” error. I found 1 topic on the forum but no real conclusive solution, even Vera Support does not seem to understand.
Vera support suggested to upgrade to the latest release (I’m on 1.7.4453) but reading here on these forum clearly is a no-no for me as it would break some things only make a bad situation worse…
| 4 | 04/15/20 8:03:39.152 | <0x766de520> |
| 04 | 04/15/20 8:03:39.153 | <0x766de520> |
| 01 | 04/15/20 8:03:39.153 | ZWJob_SendData::Run job job#3 :secure node 31 dev:6505 (0x1069968) N:31 P:38 S:3 Id: 3 device 6505 node 31 Aborting without requee after 2 retries <0x766de520> |
| 02 | 04/15/20 8:13:41.101 | Device_Basic::m_eConfigured_set device 6505 was 0 now -2 zw configuring <0x76cde520> |
| 01 | 04/15/20 8:13:52.181 | ZWJob_SendData::Run done/fail job job#17 :secure node 31 dev:6505 (0x10fd530) N:31 P:38 S:7 Id: 17 took 11075 ms method 2 to node 31 command 152/2 failed 5 retries 0 of 2 <0x766de520> |
| 01 | 04/15/20 8:14:03.262 | ZWJob_SendData::Run done/fail job job#17 :secure node 31 dev:6505 (0x10fd530) N:31 P:38 S:7 Id: 17 took 11079 ms method 2 to node 31 command 152/2 failed 5 retries 1 of 2 <0x766de520> |
| 01 | 04/15/20 8:14:14.341 | ZWJob_SendData::Run done/fail job job#17 :secure node 31 dev:6505 (0x10fd530) N:31 P:38 S:7 Id: 17 took 11079 ms method 2 to node 31 command 152/2 failed 5 retries 2 of 2 <0x766de520> |
| 01 | 04/15/20 8:14:14.342 | ZWJob_SendData::Run job job#17 :secure node 31 dev:6505 (0x10fd530) N:31 P:38 S:7 Id: 17 to node 31 command 0x98/0x02 failed 2/2 or Quit 0 <0x766de520> |
| 01 | 04/15/20 8:14:14.342 | ZWJob_SendData::JobFailed job#17 :secure node 31 dev:6505 (0x10fd530) N:31 P:38 S:7 Id: 17 Priority 38 <0x766de520> |
| 02 | 04/15/20 8:14:14.342 | ZWJob_ConfigureNode::ChildChanged aborting job#16 :conf_jh#31 dev:6505 (0x1d1b098) P:39 S:5 Id: 16 for job#17 :secure node 31 dev:6505 (0x10fd530) N:31 P:38 S:7 Id: 17 <0x766de520> |
| 02 | 04/15/20 8:14:14.343 | Device_Basic::m_eConfigured_set device 6505 was -2 now 0 zw aborting <0x766de520> |
| 04 | 04/15/20 8:14:14.344 | <0x766de520> |
| 04 | 04/15/20 8:14:14.345 | <0x766de520> |
| 01 | 04/15/20 8:14:14.346 | ZWJob_SendData::Run job job#17 :secure node 31 dev:6505 (0x10fd530) N:31 P:38 S:3 Id: 17 device 6505 node 31 Aborting without requee after 2 retries <0x766de520> |
