Hello ,
I have a vera3 with UI5 with a bunch of Fibaro 221 double relais.
In the early days, this showed up on UI5 as a parent and 2 child devices , but on my latest UI5 version this was changed in 2 devices , which made more sense.
With some problems I removed the relais from UI5 and installed in on my new vera plus , but I see again 3 devices.
Did I do something wrong , or is this the standard again , 1 parent and 2 child devices :
On a second note , what is the best option the unpair devices from UI5?
Initially I deleted the device from UI5 , but I couldn’t include it in UI7 on the vera+ , in the end I had to phsicially remove the device and remove it from the mains and reset it. Is there a better option , so I don’t have to remove the device from the mains?
Thanks,
Cor
