Hello,
I have 3 FGRM-222 Roller Shutters. I control them either via UI7 on my Vera 3 or either via the Wall C wall Controller (from Z-Wave>Me).
Via UI7 it is pretty easy; just click on “open/close” or “Up”/“Down”. Or choose a percentage. Works perfect.
But than the Wall C.
I can perfectly get them in 0% or 100% with the controller. Just press the top button (1) or the bottom button (3), to either go ‘up’ or ‘down’.
Then, my questions:
hold the top button (1) and the roller shutter should go up until I release the button. Shutter should stop. This works, but reversed. So, if I press the top button, the shutter goes down, until I stop. Same for the other way around…
Can anyone help on how I should get this the other way round? So ‘holding up button’, means shutter goes up? -
when I press shortly on the e.g. top button(1), the shutter goes up. Fine. But than I want it to stop. I cannot get it stopped. Is there a way to do this? For example to press again on the same button or something like that?
Thanks for your answers in advance!
