Fibaro FGRGB-1 Last Memory not working
Hi
I have a Fibaro FGRGB-1 with controlled by a Vera Edge. This is working perfect exept that after power failure the last stat wont be stored and most time the module is coming bacck at 0% insted of 100%.
Can somebody explain me wehre i find this setting in the Vera Edge?
Config looks like this now:
Capabilities
211,156,0,4,17,1,L,R,B,RS,|38:1,39,49:2,50:2,51,96:3,112,114,133,134,
switch to input type text
ManufacturerInfo
271,2304,4096
VersionInfo
3,3,52,25,25
Configured
1
NodeInfo
26,27,31,32,33,60,70,72,85,86,
MeterType
1
MeterScale
5
SupportedColors
W,R,G,B
MultiChEndpoint
5,0,1
MultiChCapabilities
1,17,1,38, 2,17,1,38, 3,17,1,38, 4,17,1,38, 5,17,1,38,
ConfiguredAssoc
ModeSetting
1:;2:;3:;4:
LastUpdate
1461845606
FirstConfigured
1461845606
Neighbors
1,
LastReset
1461845605
AssociationNum
5
ChildrenSameRoom
1
LastRouteUpdate
1461975367
LoadLevelTarget
100
LoadLevelStatus
100
Status
1
Watts
0.0
Log
0,0,0,1461994200,1
ActualUsage
1
PollNoReply
519
ConsecutivePollFails
360
KWH
0.1200
KWHReading
1461963112
CurrentColor
PollOk
1068
LastPollSuccess
1461962852
VariablesSet
1,m,
VariablesGet
1,255,
ConfiguredVariable
1,m,
PollSettings
60
Target
0
LastNnu
1461974400,2
LastArr
1461974400,2
You’ll find the setting in the FGRGB-1 manual.
The setting you wish to enable is the default setting and usually does not need to be configured. But try setting Parameter 16 to 1 Byte Hex Value of 1. (How-to configure parameters(variables).)
If the setting takes and it still doesn’t remember its pre power failure state, then the switch may be defective. Before replacing the switch, be sure to try excluding and including it again, to completely reset it to factory defaults.
Thanks for the help.
I did try to make the described setting with succsess but still after 10h out of power the dimmeer goes to 0% and it should be 100%.
Also I did do the factory rest to and had a try, still the same.
Do you think its defect? Should I buy an other one to compare?
It sounds like a defect. I would try contacting Fibaro or the vendor you got it from for a replacement.
I know this is an old topic, but how should I change the Parameter 16 to 0 (I need to turn off after a switch stops being pressed) if I just see the screen like this?
I do not see this configuration screen with this device :frowning:
Hi ddavid,
Just stumbled upon your post by accident and realised you never got a reply for such a basic question.
You are on the wrong page. Go to “Device Options” instead. If the setting you want is not in there already then press “Add configuration setting”. A new blank line will appear above where you can enter those values before pressing “Save Changes”
