I have bought Somfy Glydea 60e WT motor and Fibaro Roller Shutter FGR-221.
I have connected them but I’m having a problem.
In Veras UI5 dashboard when I push open or close button mo motor is doing only one rotation.
I have contacted to Fibaro support center and they told me to change parameter 10 value.
Please help me how I can do that .I’ve tried in Device options bu still I have no solution.
I think that I couldn’t change the parameter value.
Please help me in resolving my problem.
Open the device block for your FGR221 by clicking the wrench. Select the Device Options tab. Click the Add configuration settings button and enter 10 in the Variable box. Now select 1 byte dec from the drop-down menu and enter the setting recommended by Fibaro into Desired Value.
Close the device block by clicking the X and click on Vera’s Save button. You should see blue messages displayed on the device block as the new configuration is sent to the FGR221. To finish, reload your browser page. If you open the device block and the Device Options tab, you should see the new value for variable 10 displayed under Current Value.
