I have successfully integrated a Fibaro FGK101 in my Vera setup, it works fine, including the temp sensor, however I do not understand how to get an alert if the tamper switch is released, anybody knows how to set up a scene and receive that event?
In the manual they mention that group 2 (of the association groups) is for the tamper switch. group 1 is for the binary switch and the magnetic switch. So you can try add a siren to the group 2 of the Fibaro switch.
So under device options in Vera add group 2 and then tick the box next to a siren or virtual switch or something like that. Please let me know if it works.
This should send a signal straight to the siren bypassing the controller so it does not even need to be armed.
Also to deactivate the LED light (to save battery) add parameter 2 (size 1) under device options and set it to 0.
