Fibaro fgd211 vera3 + merten button [solved]
Not sure if I understand this light dimmer.
If I pair “Merten Move Modul 1” button with it I can’t add it to vera.
If I pair vera with it I can’t pair it to merten move button.
Have it something to do with that the merten button is an zwave device type=controller and the vera is an controller?
anyone tried something similar? any tips?
Solution:
pair merten button and the dimmer to vera.
Merten button is battery driven, and I found out that vera dosen’t add it unless you keep clicking on button (three times is the normal procedure to go to learning mode)
Then in vera configure assosiation under merten device, and then assosiate it to fibaro dimmer. group id I got from merten datasheet for the button/switch.
