Just got the Echo Dot yesterday and found Veras interface to be very good, but have an issue I dont find a solution too.
-Fibaro Dimmers only shows up as on/off. ie. I am not able to adjust brightness. Anyone having had similar issue?
Anyone else experienced the same issues?
Same boat here… And haven’t found a reason nor a solution…
Fibaro Dimmers are seen as on/off only, while my Hues work as expected…
If anybody has a clue, thank you in advance…
Joe
Hell??? Nobody else having this issue? :o :o :o Thank you for any input, guys! Joe
Hello, My issue is the opposite, I have a fibaro Dimmer 2, and it’s showing up as a dimmer (as it should) but I want it showing up as on/off only… any thoughts?
Sups
