all the Hints i found where from the GE systems … which have a 3 way z-wave switch … but they all foe 120 volts so far as i know.
so i had the short idea to simply keep the old switches as they are … and connect a fibaro dimmer arround the lamp where i also have permanent power and ground avaiable.
question now is that doable ? using the secondary input of the fibaro dimmer ? or just with a single one ?
this would also solve my general Ground problem, since there is no ground wire avaiable in the walls with the switches.
Multiway wiring is simply a way of making several (or lots of) switches act as one - changing state on/off when any of the component switches is changed. As such, there really ought to be two wires which come to the lamp from either end of this ‘virtual switch’. Connecting those up to the Fibaro module switch contacts, and wiring the live, neutral and lamp directly to the appropriate connectors of the module should work just fine. You will need to set a configuration parameter (I think, #14 from memory) to say that you have bistable (ie. standard) switches. (The dimmer module defaults to monostable switches) (You’re not actually trying to dim, are you?).
Alternatively, replace the switches with momentary ones and then the wiring becomes very easy - you just wire them all in parallel across the module switch connectors.
Don’t like the sound of not having an earth available at every wall box…
Using momentary switches is the easiest way as they daisy chain as many times as you like.
The alternative, if you already have a 3-way installation, is to leave the switches as they are and wire the dimmer module Sx and S1 to the switch L1 and L2. I can create a diagram for you if that would help.
i think i give it a try with the standard setup.
set parameter 14 and all good …
i dont really worry about the switches, but it must be “wife-compatible”
and i dont want to change too much (i dont own the house) and the electrical setup here let you grow gray hair if you see behind a switch.
based on that i think putting a fibaro dimmer near the lamp and pull permanent power is the most easy aproach (i guess)
the switches supposed to do “on/off” only, preferred would be the physical switches to trigger 100% and 0% (on off)
the dimming is done by the veralite depends on other criterias (well thats my plan)
