I’ve been having an ongoing issue whereby Fibaro relays, when used in conjunction with Saturn Clipsal wall switches with in-built blue LED backlight, have had a number of compatibility issues.
I have recently installed a couple of Fibaro relays (double FGS-223 and FDG-212 dimmer, see schematic attached) in a junction box in a roof space where the associated wall plate switches do not have neutral wires to them (and no way to chase any down the wall). With the Saturn backlights on, the Vera still works effectively to activate the lights through the z-wave system, however the wall switches don’t work at all. So the only solution has been to disconnect the blue backlights off at the wiring on the back of the wall plate and after doing so, the manual switches work. This is annoying but I can live with it. I?d actually prefer the backlights are ‘constant on’ but again, because of what is likely a leaking voltage through to the Fibaro relay, it means the wall switch doesn’t work.
The ability to disconnect the blue LED button backlight is not possible however on the momentary Saturn dimmer buttons (the module is integrated). Even finding a way to run a neutral here won’t seem to solve this because of this module integration (there’s no neutral connection from it, see attached). The only answer would seem to get a type of wall plate with separate switch and separate dimmer, but I’m just not convinced I’d have to resort to that. SURELY there is a way of getting a Fibaro FGD-212 dimmer module working with a Saturn momentary dimmer button with integrated blue backlight (which is MADE for dimming)! These are off-the-shelf products and are often mentioned as compatible.
If anyone has seen or knows of a solution I’d be much obliged. The only thing I can think that is happening here is that due to the lack of a neutral, the Fibaro FGD-212 doesn’t detect a change of state and so won’t switch. In saying that, could there any way to change the “tolerance” of the Fibaro (one of the parameters?) such that, say, anything under 200V is regarded as zero, so that when 240V passes through, this will trigger a change of state? Without the neutral, the Saturn wall plate LED leak-through obviously takes it above the current tolerance and so a change of state isn’t detected when the button is pressed.
Any ideas would be much appreciated.
